1 - 13 of 13 Posts
I am swapping in Toy axles, I have heard a front Toy driveshaft with a "CV" will work with the centered diff. Will it bolt up to the flanges of the newer Sammys? If so anyone got one they want to sell? Also what are you guys running for the front? <IMG SRC="smilies/usa.gif" border="0">
check out izook.com in the tech. section it explains it for you with pics.......
the CV joint will not work due to the fact that you will have 2 angles to work with. The rear end must point directly to the Double cardan joint to prevent vibs. This would be impossible for the rear end, but the front may be ok if the pinion is pointed raight at the transfercase flange.
If you can keep your rear u-joint angle with in 3-4 degrees of the t-case you can run a CV at a compound angle. That is what they are designed for. <IMG SRC="smilies/smokin.gif" border="0">
I gave you the text book answer! How many degrees do you think the left to right angle would be with a centered diff? Im guessing 6 to 7 degrees. whad dou think? <IMG SRC="smilies/confused.gif" border="0">
I think it will be fine, cause no one else has had any probs with it, dont suppose I will either! <IMG SRC="smilies/eek.gif" border="0">
I put a double jointed front yota shaft in the rear of my sammi and it works great. You do half to get the re-machined flanges from trail tough. they run about 40 bucks for the pair.
Discussion Starter · #12 ·
I believe the flanges on the newer sammys mate directly with the toy driveshaft. Mine the toy fits a little loose, and I think it would be hard to line everything up to redrill for the new shaft. Do the ones Trail Tough have bolt up directly?
1 - 13 of 13 Posts
