1 - 4 of 4 Posts
I have for sale a front and rear toyota axle. Front is a 79' and rear is IFS width of unknown year.
The rear axle is stock with 4.37 gears and a welded carrier.
The front is open with 4.37 gears. It has had IFS hubs and calipers installed along with FJ rotors to make it match the width of the rear. It has trail gear high steer installed. The steering has only been on 2 runs. When I did the high steer I also added a 5th stud to the knuckles, steering and ball gussets. The bearings and seals were all replaced at the same time as the steering was installed. This axle is complete hub to hub ready to run. The steering is complete minus pitman arm.
Only reason axles were removed is that I am going bigger. Both axles work fine and have no broken parts as far as I know. Although the front pinion feels like it may be due for bearings.
I'd like to get 600$ for the pair.
I have the stock front hubs and calipers for sale as well. Make offer.
Shipping on your dime.
1 - 4 of 4 Posts
