1 - 20 of 26 Posts
Ftoy #024 For Sale
Chassis
1983 Toyota Frame
Hendrix Ftoy Chassis #024
Added shoulder bar for seat belts and cross brace in back
Ported for Air storage in chassis tubes
Recessed Side panels with Dzus fasteners
Full aluminum interior panels Floor back and firewall
Suspension seats
Billet quick disconnect steering wheel
Full aftermarket swinging pedals with separate master cylinders
Full gauges Tach, Volt, Water Temp, Oil Pressure and Air pressure
Center Dash holds all Gauges and Switches including Key switch
Red top Optima battery
Billet Optima Battery mount under dash with disconnect
Dash top has Dzus fasteners
Dual Propane tank mounts in rear
9000[b winch in front with dash mounted control
Drivetrain
Fresh 22R on Pane
GotPropane Kit with 5 tanks
PSC P/S pump with Hydro assist and fluid cooler with big reservoir
A/C compressor converted for air with oiler and separator
Compressor has auto pressure shut off switch set a 100psi
Valved to fill chassis air storage or only run ARB
LCE long tube header
Full exhaust out the back Heat wrapped from head to back
New radiator before KOH 2014
electric fan with auto thermostat and kill switch on dash
Gm 1 wire alternator
L52 trans
AA doubler 2.28 front 4.7 rear twin sticked
Cv long slip front shaft
Front axle
84-85 front housing
Completely trussed and bottom shaved with custom front rock protection
Ball gussets
Hi steer arms with 5th stud
Arb knuckle and hub studs
Heim joint on steering rods instead of ball joints
ifs calipers with fj rotors backing plates deleted
Stainless brake lines
Hi pinion 5.29 third with ARB
Bobby Long 30 Spline axles with chromo hub gears
Rear Axle
Ifs width
shaved for clearance and custom rear cover rock protection
Stainless Brake line
V-6 third 5.29 spooled
Chromo Rear axle shafts
Suspension
3 inch allpro buggy spring
5150 bilstein resi shocks
Rear springs inboarded and front of spring flush with bottom of frame
Wheels and tires
38x12.50x15 Swamper Tsl's 85% tread but have rash hold air fine no plugs
15x8 steel wheels Beadlocked
Other stuff
Complete LED Rock lights under buggy along with LED tail lights
Cb on dash
Ipod Cord with Pre amp and 2 amps 1 for sub and 1 for boat tower speakers
I'm sure there is stuff I'm forgetting I will add it as I remember.
You can see some of the build here
Pirate4x4.Com : 4x4 and Off-Road Forum - Powered by vBulletin
I have wheeled this buggy just a handful of times since I finished it
2 Koh trips
1 rubicon trip
3 local easy trail runs
1 dunes trip
unbelievable how amazing they due.
Feel free to call or text with any questions
asking $7500 obo
Thanks Robert
15416010042
You can see it in Ftoy section also here
http://www.pirate4x4.com/forum/toyota-formula-toy-forum/685417-formula-toys-sale-wanted-18.html
1 - 20 of 26 Posts
