1 - 16 of 16 Posts
OTT adapter that mates a Toyota reduction box to a Dana 300. Comes with Toyota box and X-member, you supply the Dana 300. Only used for 5 trailrides since I bought it last spring.
$500 plus shipping.
Tass
If you would have only posted this two weeks ago I would have taken it....... :(
I just get mine from O.T.T.
Discussion Starter · #12 ·
Yeah, it's been sitting in my garage for a little while. I should have listed it sooner :D
McSoo, Pm'd ya back.
Tass
Tass said:
I'm looking at a Northstar V8, auto tranny and Dana 300 setup :D :D
Dual cases and automatic with Mog's are overkill IMO
Tass
sounds like a sweet set up!!
I'm thinking to use a 203 reverse cuppled to a 205 th400 and looking into a big block power on mog's
The 203 acting like an over drive! (.05to 1)
Also thought about LS1 and other aluminum block power,and then realised that the extra weight of the big block was kind of minor compared to 49" Irock's, 20" beadlocks, mog's,etc.
I'll be lucky to keep mine under 5000lbs!
I figure a bone jard 454 with a bit of cam & head work should net around 500HP with out sacraficeing reliability!
Prolly could be done for around 1500-2000 canadian!
P.S. did you get your axles from Mike in Orillia?
Thanks
Discussion Starter · #16 ·
Thanks
Sent you a PM.
Tass
1 - 16 of 16 Posts
