Marlin Crawler Off Road now has a complete line of Toyota knuckle service parts in stock:
Knuckle Service Kit
Includes all the standard knuckle service parts: wipers, felts, gaskets, lock washers, inner axle & bearing seals, hub gaskets, knuckle shims, and knuckle bearings. Made in Japan and features Koyo bearings. Fits 79-85 Pickup/4Runner, FJ40, FJ55, FJ60 & FJ-62. Kit does not include wheel bearings. Kit covers both left and right sides. $95 (kit covers left and right sides)
Front wheel bearing kit
Kit includes inner and outer wheel bearings, wheel bearing seal, hub gaskets and lock washer. Kit covers one side only. Kit features quality Koyo bearings, made in Japan. $39 per side
Factory replacement knuckle parts
Upgraded knuckle stud, Toyota now included a Torx E12 on top. This make it easier to install or remove into knuckle. Fits 79-85 Toyota front axles.
Knuckle Studs $1.25 each
Knuckle Stud Nuts $.50 each
Knuckle Stud Split Washers $.60 each
Knuckle Stud Cone Washers $2.99 each
Caliper Brake Hard Lines, Left or Right Side $4.99 each
Inner Axle Seal
Sometimes a leaky front axle needs only a new inner axle seal to repair. It's also common for this seal to be damaged when a Birfield fails. $4.49 each
Knuckle Service Tools
The scale allows you to measure the knuckle shim preload. To use: remove tie rod, attach the scale to the outer knuckle. Then adjust the shims until it takes 12-15lbs of force to rotate knuckle.
Snap-On 54mm Hub Socket $24.99
Knuckle Pull Scale $9.99
Knuckle Service Kit
Inner Axle Seal
