1 - 9 of 9 Posts
1991 pickup that won't get any spark. I stalled it on a trail last weekend, and ever since it won't spark. Already checked coil, wires, plugs, cap, rotor, and changed ignitor. I am confused, what else could be causing this problem? Does the ECM have anything to do with it?
· Premium Member
i agree with fuse under the hood. had the same thing happen to me. gauges died, everyhitng but it still ran until i shut it off.
Do you get any power when you turn it to the on position? Does your gas guage show power when u turn it to the on position? If it doesnt, check the AM2(i think) fuse under the hood. the vehicle wont get any fire if this link is dead.
Also, it could be the one of the relay switches in the fuse block under the hood. I had to replace one once but i cant remember which one it was. I'm pretty sure it was the silver round one. (starter relay) Whenever u take off the + terminal and touch it to the battery, you should hear it 'click'. If it doesnt, replace that.
check fusible link, make sure all connections are tight, no shorts anywhere. by saying it doesnt have spark, i'm assuming it turns over. make sure all your grounds are still attached, etc. if your not getting fire at the coil pay attention to any connectors related to it first, then look down the chain...
I'm not familiar with 1991 but you didn't mention anything about the pickup coil inside the distributor. This has the magnet lobes going past it, telling the ignition when to fire. The sensing surface has to be close enough to the magnet lobes too. An ohmeter will tell you if that coil is good or not.
dead
I would check the coil resistance (see manual for values) and see if you are getting power to the ignitor/coil assembly, most likely not. Then check the wires going to the distirbutor and make sure there aren't any shorts or open circuits.
Jeff S.
1 - 9 of 9 Posts
