That looks awesome! Can't believe we didn't get double cabs in the states until the Taco.Doron_B said:
Not even close. Our 2005 Tacoma was totally redesigned, but includes an entirely new frame that is essentially a carbon copy of our Tundra frame, which is C-channel from the mid section all the way to the rear and includes a funky rear suspension shackle system similar to some of our domestic makes. The only thing that it remotely shares with the new Hilux is the front suspension, which came from the 2003 and later 4Runner. I think the interiors might be similar too, but that doesn't mean jack when your on the trail.customhilux said:do u have the new AUV hilux in the states.
tassie devil said:as far as i know,hilux's never came out with a floating rear end.im just in the process of modifying a f/f land cruiser back end to fit my 85'
One of the solid axle trucks on the Japan market section of this web site appears to be using Toyota OEM aluminum rims like the US had from 86-95.PAToyota said:Check this site out:
http://www.brian894x4.com/FOREIGNTOYOTAMAINPAGE.html
Lots of information on all the models that never made it to the US...
My understanding was that IFS and SA wheels fit on both trucks just fine. I know I used my same wheels on my IFS and SAS set up.HMI1 said:One of the solid axle trucks on the Japan market section of this web site appears to be using Toyota OEM aluminum rims like the US had from 86-95.
Did Japan change the front axle or hubs etc to fit these?
Toy factory aluminum wheels for 86+ IFS trucks have too small a center hole to fit over a soild toy axle, & the BS is such( 4.5"? vs 4" or 3.75") that the tierod will hit the wheel.Brian894X4 said:My understanding was that IFS and SA wheels fit on both trucks just fine. I know I used my same wheels on my IFS and SAS set up.
I've seen the aluminum SR5 wheels on a few SA trucks...SeaBass44 said:Toy factory aluminum wheels for 86+ IFS trucks have too small a center hole to fit over a soild toy axle, & the BS is such( 4.5"? vs 4" or 3.75") that the tierod will hit the wheel.
I have no idea what wheels you had/have, but a good guess is they were aftermarket wheels with more BS so they swapped right onto your solid axle after the swap. Most chevy wheels have the center hole too small to fit a toy too, both steel & aluminum. Ask me how I know :evil:
It's a DRW setup and I beleive it has 6 lugs but I know there spread out in a much larger bolt patern. I did an engine overhaul one one over the winter and never looked at the third member to see what it was.MT4Runner said:RockStomper-Toy, were the 2wd units the small 5 on 4.5" lug pattern (can't see how they would be with room for a FF hub), 6 on 5.5" like our 4wd's or the big 6 on 6.5?" like the DRW motorhomes? Still 8" diff in the middle?
This truck is under the Japan market section, sure looks like the stock 86-95 US aluminum rims: http://www.brian894x4.com/teruzou01.jpgrockota said:I've seen the aluminum SR5 wheels on a few SA trucks...You do need a wheel spacer, but the hub center shouldn't be a factor.
At least around here the SA until 98 and the IFS after 97 have the same rear axle, width and housing. The difference us with the r&p ratio. The SA has 4.56 and the IFS has 4.10Oatmeal said:Do those later model solid axle trucks have a wider rear axle like our IFS trucks and a correspondingly wider FRONT axle? :idea: ........Hans
