I'm replacing the bad TPS on my 89 SR5 truck (22RE). I ordered a new unit from NAPA giving all the pertinent info. I get home, pull the throttle body (it needed a good cleaning), remove the old TPS and wouldn't you know......the new sensor is wrong.
The fins for the wiper are 90 degrees offset from the original sensor. It won't hook up to the butterfly valce correctly. Dammit!
I, being a dumbass, didn't bother to verify that the Toy part #'s matched before I removed anything.
My truck uses a 89452-28030. The new unit is an 89452-14050. According to the second guy I spoke to at NAPA my original TPS is for a 22RTEC. The part I recieved is definitely for a 22RE Federal.
The purpose for my post here is twofold. First, I want to know if some of you guys could check your part #'s on your trucks and see what you have (SR5 vs. non SR5, turbo's vs, n/a, etc). I'd like to know if I just got an odd bird or what.
Second, I figure this would be a good contribution to future TPS searches.
"CHECK YOUR PART NUMBERS BEFORE YOU ORDER A TPS!!"
Anyhow, that's it. I have to wait until tomorrow for the correct sensor. This sucks.
Hef
Hef
