1 - 1 of 1 Posts
Hey guys. I am putting yota axles in. I switched the lines around so i have one output from master going to front brakes, and one line going to the T on the yota axle.
I know i prolly need a proportioning valve for the rear. I saw the Wilwood on spidertrax's site, but it is expensive.
Would a cheapo like this be ok?
http://cgi.ebay.com/ebaymotors/Proportioning-Valve-Universal-Adjustable_W0QQcmdZViewItemQQcategoryZ33566QQihZ009QQitemZ190229220686QQrdZ1QQsspagenameZWDVW
Or what about this summit brand?
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2DG3905&N=700+%2D48578+115&autoview=sku
I know i will need metric adapters for both.
Next, i need longer lines for the front. I have heard of the nissan lines and such, but i happen to have a set of stock tracker lines.
The have a female fitting at one end, and the round (i think they're called banjo fittings?) fitting that a bolt goes through to bolt it to the caliper.
Can these be used with the yota calipers??
Thank you!
Neal.
1 - 1 of 1 Posts
