NytFlyr (I can't BELIEVE you got run off of off-road.com!) I don't know how you came up with the idea that the V6 is crap. It's an incredible engine - just don't run anything but 5W30 in it, or you'll be changing timing chain tensioners every 40,000 miles.nytflyr said:did the search and found out the V6 is crap, so how can I hop up the 1.6L thats in it? it has 90k miles on it right now.
Thanks
well the changing of chain tensioners at 40k miles is where I came to that conclusionBobzooki said:
If I could steal my wife's V6 from her GV and drop it in my Kick, I would in a heartbeat! As it is, you can get a lot out of a 1.6/16, by boring porting polishing, etc. Hugh Reynolds (Reynolds Machine, Bakersfield, CA) says he can get it up to 140 HP on premium fuel, or more if you want to get exotic. All depends on how much you want to spend.
I am the guy who did the timing chain tensioner replacement on my wife's GV at 80,000 miles. It's running like a top now, and has great power.nytflyr said:well the changing of chain tensioners at 40k miles is where I came to that conclusion
do you know if it is a clean swap? I still may consider it.
Step 1: Are you in California? If so, this will make your rig not-street-legal, because there are NO CARB approved headers for the 1.6/16. The solution: Calmini Header & Hi-Perf Exhaustnytflyr said:Ummm, errr, I think Ill stick with the 1.6 then... any good sources for beefing her up?
Can't be done.nytflyr said:anyone know if the suzuki V6 would fit into a 1998 Chevy tracker?
what kind of modifications will be needed?
how much does a crate engine cost from suzuki? (I should probably just have one rebuilt)
Root Moose said:
