1 - 17 of 17 Posts
I'm sorry I searched and could'nt find anything on useing the whole married setup out of a tracker and then putting my sami case with low gears behind it. I'm thinking of swapping to toy axles and will lose my 5.12 diff gears. I have 5.14 low range gears and with dual cases I think I could have good gearing for 35" tires with stock toy diff gears. Has any body done this yet? I will likely have to extend my wheelbase for driveshaft angle but a little longer would be good anyway. Any input would be killer thanks!!
I currently have a 2.0 tracker engine with a 98 trans and transfer case doubled to a sami transfer case. It all comes out a little over two inches longer than the stock sami drive train. This is only because of the 98 bellhousing being deeper than the earlier model trackers. Does this make sense?
I can get some pictures if wanted. I'm still in the middle of building my sami too.
yes pics would be great!! nobody seems to have any info so anything would be super. I will be using a 97 tracker with the 1.6 16 valve with a 5spd trans. pics of crossmembers and interior mods if needed if you've got them. Thanks for all the help Josh
I just finished mine
I just did my own adapter, I mounted both t cases together solidly, otherwise the u joint in the middle will vibrate. with some know how and a torch and welder it can be done, it is long though so without the ott adapter the samurai will have to be stretched.
not looking for a kicker 3. looking to use a 5spd tranny and not need to buy expensive adapters ($675.00). if i build a crossmember to hold it should be ok. love to build it myself if i could.
as I said use "kicker 3" in the search, it will give you some ideas:flipoff2:
1 - 17 of 17 Posts
