1 - 19 of 19 Posts
Both of the trucks that I use to pull trailers came wired from the factory with the 4-pin or square style trailer light plugs. Whenever I borrow a friends trailer from time to time I have to run with no lights since his trailer is set up with the 7-pin round plug. Does anyone make a converter to mate my 4-pin square to a 7-pin flat or blade style plug? I have searched every parts store in town but to no avail. Thanks for any and all help.
Both of the trucks that I use to pull trailers came wired from the factory with the 4-pin or square style trailer light plugs. Whenever I borrow a friends trailer from time to time I have to run with no lights since his trailer is set up with the 7-pin round plug. Does anyone make a converter to mate my 4-pin square to a 7-pin round plug? I have searched every parts store in town but to no avail. Thanks for any and all help.
flat 4 on the truck and 7 round on the trailer.......they don't make one
The best, and about the only over the counter thing for you is what Motor posted above in the link. That's a nice setup. It gives you both the flat 4 and the 7rv. The problem is, you mention that the trailers have a 7 round pin plug. Be sure that it isn't the flat pin style plug, or 7rv plug.
If it really is the 7 round pin plug, then they don't make a plug like in the link above. The you can just buy the two plugs and wire them yourself. Flat 4 to 7 round wiring would be color to color, making your own adapter.
1998 TJ with stuff
This is what I found to be the situation as well. I don't know if it is true or not, but I was told that they would never make such an adapter commercially because it would disable the use of the electric brakes on the trailer and that would be a liability exposure that no company would want. :eek:
go to tsc and buy a convertor? or buy both plugs and make your own.
Why not just go to a 7 pin RV on the truck? That's what I did. You can adapt to damn near any trailer with that plug. Heck, I don't even have a trailer that uses the 7 pin rv plug.:laughing:
Install a 7 way rv style plug and brake controller on the truck.
Yep. Then get adapters for the rest. I have a 7rv-6 round for the car trailer, and a 7 rv-4 flat for my little trailer. I'm sure if you looked you could get a 7rv-7 round for your buddies trailer. I carry a backpack in the truck with trailer balls and wiring adapters in it, along with other things. I can be hooked up to any trailer within 3 minutes.
If his is 7 pin, it sounds like it has brakes, and if so, you need to have a controller, and wiring to support that.
Discussion Starter · #12 ·
Yes you can get a converter. I have one, I don't remember where I got it from though.
Thats good to know. If you can remember where you got it and have some contact info that would be great!
Discussion Starter · #14 ·
Thanks alot for the info. I had a typo in the first post. The trailers I borrow whenever needed are the 7 blade style of the plug not 7 round. Can you tell me some more info on the converter that motor mentioned?
Discussion Starter · #15 ·
I went to TSC and called the manufactuer about the converter from 4-pin to 7-blade and they said they did not make one and would not make one due to too much liability involved.
Well now that I have seen what other options are out there instead of at TSC and other parts stores, I may just do that. Thanks for the advice.
There IS a 4-7 adapter made. We stock them.
That other Multi Tow adapter is actually a pretty nice piece. It plugs into the flat 4. You connect the ground, mount the bracket and socket, and you are done. It has pigtails for the brakes, 12V+ and Aux already built in, so all you need to do is connect wires to them when you are ready.
That "adapter" is not a true adapter. That is just to ease the installation of a 7 way plug when someone already has a 4 flat connector on their tow vehicle. If it was a true adaptr, it wouldn't have the brake, charge, back-up, and heavy ground wire coming out of the back of it.
That's the way I see it, too. It seems hack to go that route, rather than properly hard wiring the 7 way, IMHO. Once you have the 7, you can stick an adapter in for anything else.
NOTE: Be sure the adapters work right. I bought a 7rv-6 round adapter right before I helped my parents move to run their (now mine) car trailer. The lights were all jacked up. I had to run between two of our other vehicles with no lights. Dad blew a tire 100 miles down the road, and needed a new one, so I started puttering in a gas station parking lot and found out they had installed the 6 round side of the adapter 180* out. THe kicker is, it's molded to go in one way, so I had to wittle down the tabs with my knife to be able to flip it.
Discussion Starter · #19 ·
Thanks alot for your help and pointing me into the right direction with etrailer. I just placed an order for one of the conversion parts so I can hook up to whatever trailer I want. It should be here in a couple of days so then I'll go test it out. I ran by TSC in town and they were out of the particular converter that I wanted so I just decided to place the order with etrailer. Than ks once again and I'll post up how everything works.
1 - 19 of 19 Posts
