just swapped the input shafts from a 205 that was behind a sm465 to a 205 that was behind a th350. everything went in easy and good but with the sm465 bolted together with it. there is a lot of play between the T-case and Tranny( a little less than a 1/4 turn on the output of the T-case). is this normal
it seems as though the play is comming from the sleeve in the adapter that connects the 205 to the sm465
