1 - 3 of 3 Posts
I shift into first and let out the clutch and give it gas and if I am not holding the stick in place.....BAM......it pops out really loud into neutral. this only happens in first gear though. whats up???
Frist replace the shift handle green seat and nylon socket.
If this does not correct the problem, you have a wasted main shaft bearing and or retainer plate that is allowing the main shaft to move rearward on acceleration [due to the side thust of the helical cut first gear]. This will walk the shift collar out of gear.
Marlin
1 - 3 of 3 Posts
