I have a 68 Scout 800 will an auto tranny from a V8 Scout bolt up to the 196 in mine??? PLease help.
Elaborate on this a little.Dont be surprised if its a dawg
Take the sluggishness of a 4 cyl in a heavy truck, and then compound it through a slushbox tranny.scoutman72 said:
Finding a torque converter that is the correct stall for the 4 banger is another consideration as well.binderbound said:
The 4 cyl needs all the help it can get when it comes to laying down power and the auto doesnt help in a daily driver. In a dedicated trail rig or crawler it 'might' be ok if you had enough gears (crawl box, 5.88's, etc...)
Like a converter that gets around, if you know what I meanOld Scout said:It's going to need to be a loose converter,
Higher than stock stall speed. Not sure what stock 727 is. Somewhere around 1,600 - 1,800? Looser would be anything higher. I'd guess 2,200 to 2,400 would be about right.binderbound said:
Like a converter that gets around, if you know what I mean![]()
I'm not sure what a loose converter is?
