1 - 12 of 12 Posts
My friends Dad towed there sammy in 2nd in the transmission and neutral in the transfercase.Now the transfercase lever is stuck:confused: what happened:confused:
thanks for the help.......
It's likely the shifter sheet.
A replacement sheet cost about $10.
And you don't have to pull the t-case to replace.
I'm not at home, so I don't have directions with me.
I think you push down on the t-case shifter and rotate counter clockwise. This will pop the shift lever out, and you can see the rubber o-ring (sheet) in a round cup.
If it is broken, smashed, or severely cracked it could cause the shiter to get stuck - usually in neutral or 2WD.
Check the links in the FAQ section of this page and you should find useful info.
Rather than be upset with the zuke 101 questions, when i see them I will be simply copying the factual technical content and add it to the FAQ....
RANT....
I am continually amazed at the total lack of self motivation by people who obviously can't help them selfs..... How do you people get by in real life ?
I searched google with the following words...
"suzuki samurai case shift"
Guess what i found....... More than enough info to help with problem determination....
I also searched PBB zuke forum with "t case AND stuck"
http://www.pirate4x4.com/forum/sear...d=454136&sortby=lastpost&sortorder=descending
while there was more crap to look through I was able to sift thought 4 threads and find similer advice as was posted in this thread....
I have added the content provided by silverzuke to the FAQ and added some other comments, anyone willing to take the time to critique or add other comments please do, ill see they get added....
snip.....(other snide comments/remarks removed)
-yag
The starter on my Zuk goes click, click, click and then after a couple of tries, it starts.......
Whatever, whatever could be wrong??? Can someone please help me resolve this oh so desperate situation??
:rolleyes: :flipoff2: :flipoff2:
Damn you guys are funny today:flipoff2: :D :flipoff2:
your shifter sheet is shot , more than likley your shifter is stuck between the two shift rail in the case, you can fix it now by removing your shifter, and taking a long screwdriving and prying the shiftrails untill the notches on them line up with each other and then reinstall the shifter and your good to go!, ive driven mine without a sheet at all eversince ive owned it, and ive had to do that only once, you do need a sheet though!! even i got one now!:flipoff2:
zukzilla4x4 said:
yeah try cleaning it first if that dont work it time for a starter
Thank you so, so, so, much for the valuable information. I don´t know WHAT I would have done without your assistance.................
SFN:rolleyes:
Some people just don´t get it...........
1 - 12 of 12 Posts
