Hey I went to transplant my old door internals into my new non bent FJ62 rear door, how do you transplant the stationary glass and even the moving glass, its not bolted to the metal like the front is, my haynes manual doesnt tell shit.
If kinda like my fj80 and its been a while. the fixed glass can come out once a screw is removed in the vertical bar between the fixed and moving glass, should be under the weeather striping/rubber or whatever
The moving glass, doesn't it have bolts on the metal bottom part? or maybe you have to slide the arm out of the track?
Prett easy. Remove WS there is a small screw on top of the door that holds in the runner between the fixed glass and the window glass. It is held down on the bottom by a 6mm bolt or 2. Just keep taking stuff apart and it will all come out. 15 min job to strip it all.
