I'm trying to get my daily driver back together. It's getting a true track in the front Dana 44. I am not getting good backlash readings. So I look carefully and they put such a big radius in the corner where the shims go under the bearings that the shim won't sit flat on the sholder. Tryed some shims from a different kit but they're the same. The bearing goes on fine because it has a big radius too but since the shims won't sit flat backlash is all messed up......
Damn damn- I wanted it back together tonight. I don't want to grind out the inside of the shims with a die grinder. I guess I could chuck it in the lathe and square up the sholders. Anybody have an answer please?
