1 - 5 of 5 Posts
I'm building a set of custom wheels for 2.5-ton rockwells (actually still under a deuce), and I'd like to calculate the scrub radius so I can decide what offset I should go with. What's the distance is from the center of the u-joint to the wheel-mounting-surface? What about the kingpin inclination angle? Anybody?
I can help you figure it out if you're willing to take your own measurements....
I'd need you to provide all the data in the blue cells (and maybe a couple options for the backspacing that you want) and I can give you some numbers.
The nice thing about this calculator is that it will also show you visually if you're going to have interference issues, especially with the upper kingpin.
-G
:usa:
1 - 5 of 5 Posts
