1 - 9 of 9 Posts
First one:
SP-135T Output Range (amps) Low - High 20 - 115, Rated DC Output (amps) 100, Duty Cycle (%) 20, Arc Volts 17, Input Voltage (AC) 115, Weight (lbs) 56--PRICE INCLUDES 2#.030 ER70S-6 WIRE/HOSE/REGULATOR/VIDEO/WELDING HANDSHIELD - $479
Second one:
Millermatic 130XP 110 Volt Wire Welder
Description:
Millermatic 130XP 110 Volt Wire Welder, Rated At 90 Amps 20% Duty Cycle, 3 Year Warranty
Manufacturer: Miller
Order Number: 903-556
Price: $495.00
I've heard good things about both companies, but heard in the smaller welders the miller is the way to go. Any one used either of these? I will probably run down to the local shop to check them out before I order and to price the tanks but was hoping for some advice from others also.
I was concidering the hobart, but didnt know they were now made by miller. I will probably get one of those cause like glenns post they are cheap.
Paniolo: The problem I see is if I get 220 I will have to run a LONG extension cord from my drier in the basement to the driveway on the other side of the house, i think there would be alot of resistance and I would trip the breaker alot.
i recently got a Hobart 175, it's not as heavy duty as the comparable miller but if you're not gonna weld as a profession it will likely last your lifetime. go big and and get the 220V 175 you wan't be disappointed. $550 shipped from cyberweld
if you search for hobart in the gen4x4 section you can find a thread where a guy details the differences between the hobart 175 and the miller 172.
- jack
[ 10-01-2001: Message edited by: morpheus ]
Originally posted by NE-RokToy:
<STRONG>Do you guys see a problem with running a 50' cord from outlet to welder?</STRONG>
They're expensive. That's all. <IMG SRC="smilies/biggrin.gif" border="0"> Instead, I put 30' leads on my stick welder and kept the 5' cord..
On my 110V MIG I have a heavy gauge 80' extension cord to make it mobile.
What about just wiring an outlet to the garage for 220V? 6-gauge 3+G is around $1.50/ft.
-Tom
1 - 9 of 9 Posts
