first, I've read the post 4.0L swap/spark problems
so heres where i'm at...
I got the fuel pump to kick on and build pressure. I bypassed the computers control of the ASD relay and just hooked up the coil to power. I get spark at the coil, but not at the plugs.
the computer was kicking on the relays for 1 second then shutting them back down which is what led me to bypass those relays(fuel pump and ASD relay).
A friend was helping me and said that he could here the injectors working. this leads me to believe that the CPS and CMS are both working properly.
I do not have a battery temp sensor hooked up and I hear that if that is missing, the engine wont fire. Could the computer be disconnecting the voltage to the plugs until it recieves some sort of input that I have missed?
this is a 98 4.0L (OBDII).
A few other notes. The computer has its own park/neutral position switch. I grounded this wire so that the computer will always fire should it rely on this signal to start. Also, the harness I got with my engine was complete except for the computer plug C3 which controls the ASD relay control and output along with the fuel pump relay control and output. It also is responsible for the batter temp sensor(dont have it) and the voltage regulator signal(which I believe powers the computer). I hacked this plug from a junkyard harness and spliced in those critical sensors and such.
A few other things that i've hooked up are:
The generator field driver
generator field source
various grounds
fused ignition(for the computer)
A few things I HAVN'T hooked up:
VSS
o2 sensors
A/C Compressor clutch(no A/C)
A/C Compressor clutch relay
Tranny Solenoid Assembly(TF727 not stock)
Battery temp sensor
4wd switch
trany relay control
various other 4wd switch stuff
Speed control vacuum(and vent) solenoid control
Overdrive off lamp driver
vapor canister solenoid driver
speed control on/off switch sense
overdrive off switch sense
vapor conister pump switch driver
Evap emissions solenoid control
A/C pressure switch sense
Stop lamp switch sense
SCI recieve
CCd bus(-/+)
SCI transmit
Speed control switch signal
various grounds
VSS
o2 sensors
Battery temp sensor
4wd switch
trany relay control
SCI recieve
CCd bus(-/+)
SCI transmit
