1 - 20 of 448 Posts
Well time has finally come to put my jeep on tons. When I bought it at the end of the summer of 2005 I figured it was all the jeep I would ever need :laughing:. Then after wheeling it and more research on this site the thought of going to one tons started becoming increasing likely :smokin:. It all started with finding a 79 dana 60 front fairly local in good shape in the summer of 2007. Then I started collecting parts.
The plan:
Dana 60 front 14 bolt rear
5.38 gears
3 link front
4 link rear
Coilovers (14 front / 12 rear)
All lowers built off of RE Long Arm Skid plate
All uppers using Polyperformance universal frame bracket
What it started with when I got it:
Waggy 44 Front
Isuzu 44 Rear
5.13 gears
Locked
Twin Stick 300 with 4:1
Added some body armor lowered it a little and wheeled it for a few years.
Discussion Starter #18 (Edited)
Links just hanging around
completed and painted
All 3 upper frame brackets welded and painted
Rear axle fully welded and painted
Rear coilover towers complete
Shot of it on the trailer with the fenders modified so I can drive over them …
Short list of what’s left:
Add Triple Rates to Rear
Radiator
Fan
Steering
Brakes
Cross Over Tube
Build Front Axle
Front Drive Shaft
Gear Lube Front/Rear
6x6x6 ROCKCRAWLER!!
Links completed and painted
Good looking build you have going on here!! I had a couple questions about some things though. With the picture I quoted above are you going to do something about the gaps in the front control arms?
And the other question I had for you was about the hole/notch you cut in the front passenger framerail... are you going to plate that to reinforce the cut? I have seen a few framerails buckle when holes like that have been added.
And finally, what made you decide to mount the rear coilovers at that angle? Just where they fit the best?
Thanks and keep up the good work!
Matt
Discussion Starter #20
Yeah I edited the previous post ... that is them just hanging out before pulling them completely to finish welding and then painting.
Yes it will be reinforced.
Pretty much just like you said it ... where they fit best ...
Good looking build you have going on here!! Thanks and keep up the good work!
Matt
Thanks :beer:
1 - 20 of 448 Posts
