1 - 5 of 5 Posts
im just tryin to do some research on a 22rte swap and passed through here. what parts are interchangable between this and a 22re?
I can't think of much of anything that's not interchangable between the two motors. Things that are different, but can be interchanged:
1) Flywheel/clutch
2) Front cover / oil pump
3) Head (larger cc, lower compression, maybe a different exhaust valve material)
4) Pistons - lower compression
In terms of bolt ons, the coolant routing is a little different.
To get it to swap, you really need the 22RTE electronics (ECU, injectors, maybe AFM) - or a stand alone ECU.
Vendor
1) Flywheel/clutch
block, just for the oil drain
oil cooler, missing on the NA
Some small differenced in the vaccum system and pcv system as well!
sorry to hi-jack this thread...
but say i came across a 22rte header, turbo, harness and ecu....what would i be gettin myself into with trying to mate that with my 22re?
1 - 5 of 5 Posts
