1 - 20 of 25 Posts
I have a been thinking of ways to do a engine swap without getting screwed with emissions, here is my idea… I originally have a YJ, but, after doing some thinking, I was considering buying some old, dirt cheap CJ, taking off the front clip, transferring it to the YJ and then pulling off all of the VIN numbers off the CJ and transferring them to the YJ. There for, I now have a CJ, with YJ parts, that has to meet the old emission regulations if any at all. I have a feeling this might be kind of illegal, but the though of being able to run what ever engine I want has me watering at the mouth. I know I should have bought a CJ, but I wasn’t thinking of it at the time, and I already have my YJ set up other then the engine. Anyone have any ideas on this one?
what part about emissions are you worried about? i just did a 350 swap on an 87 in PA. passed emissions no problem. things i needed to keep in mind:
must have all emissions equipment originally on that vehicle...
cats, egr valve, charcoal canister, vacuum stuff, etc.
engine block must be equal to, or newer than original engine
i passed emissions no problem. still running dual exhaust with cats. holley avenger offroad carb. etc.
sorry i dont have any input on your idea, although i kinda like it
:D damn laws.
See, that’s the thing, you still have to have all of that stuff on there, and as much as I will try to keep emissions things on the engine, some times it’s just not feasible. And with that, I have a 94YJ meaning I need to get a 94 or newer engine, that’s a good idea and all, but if I ever wanted to put in a carbed 350 or something of that nature, I am screwed. If I were to get the VIN numbers from a older (real old) CJ I wouldn’t have to meet emissions, it’s a interesting thought, but I wanted to see if anyone had tried it or not.
87JeepWrangler
I know a guy here in PA that put a older 305 in a 88YJ. H e said that all he did was change the title. I am putting a 383 in my 92 YJ and am I guess I am going to change the title. I don't know if the other guy kept all the emissions crap on.
Where there is a will there is a way!!!
Drive less than 5000 miles a year and overlook the emission crap.
off the top of my head like stated above the title will have to be changed and that will have to be reflected on your registration sticker. the sticker is what is scanned when the mech pulls into the inspection bay. another thing : there is a sticker under the hood that usually gets scanned. i would assume youd have to do something about that as well. another thing to consider is what year cj? when i did inspections (years ago) i seem to remember it going by that. my point is if you change it to an low 80's cj you will be gaining nothing as far as whats required or not. but dont quote me on that its been awhile since ive done an inspection. hth
Discussion Starter · #12 ·
Sticker, what sticker? (Scrape sticker off) and the older the vehicle the older engine I can swap into it, (IE on from a 90 Chevy rather then a 94 or newer like I would now) also, once a vehicle is 25 years old it can be registered as a historical vehicle, meaning tires width, mud flaps, bumper height, bla bla bla, no longer apply to it. Get the point? Who says I didn’t build the vehicle from hand over the winter using miss matched part?
Title swaps are some waht common, especially here in Kalifornia. I am waiting for my new title as we speak (type:rolleyes: ). I plan to install a flat dash to help the issue, and just tell anybody interested, that I put a late model front clip on it.
For the record, here in Kalifornia, it is a felony.
Sundowner said:
just out of curisosity, why would you WANT to swap an engine in made before 1994?
Cheaper, easier to find at PnPs. Also gives you a bigger variety of engines to chose from. No headaches about having to set it up just right to get some government asshole to pass it.
I don't know if this will help, but here in Texas we are able to register them as a "home built" This lets you use pretty much anything you want and not worry about emissions. There is a little more to it but you might look into that in your state. Hope this helps.
Without knowing the inspection rules in new york, it is hard to say what your best option is.
here in NC, i still had to have all of the stock emissions systems hooked up on my 83 cj-7. Actually they don't have to be hooked up but just LOOK like they are. A wire going from the O2 sensor that disappears into the wire loom and isnt connected to anything satisfies the requirement for having an O2 sensor.
It isnt hard to get a carb'd engine that is tuned properly to pass a tailpipe emissions reading.
And how would the ordinary mechanic know that you swapped to an earlier year engine anyway? Maybe you just need to become friends with an inspector.
1 - 20 of 25 Posts
