1 - 2 of 2 Posts
Need info here. Not your typical trying to widen a Solid axle deal.
I have broken hub studs. I have a spare. BUT the spare I have is to do a disk swap on my landcruiser. So I would rather not use it.
IF I did use it. I know someone with IFS hubs I could use for the landcruiser.
Will this work. I am not trying to widen the landcruiser just get it standard width. Is this possible. Yes or NO and why. I dont want to go through the trouble of Skys kit or any of that junk. If I need to I will just try and find a SA hub.
i think youre asking if you can use the ifs hubs with no other modification? If thats right then no it wont work because the flange for the locking hub is closer to the wheel mount surface so the axle shaft would be too long. It really needs to be spaced out.
1 - 2 of 2 Posts
