1 - 20 of 32 Posts
I'm voting for "cut that way"--they're too straight not to be. Looks like they were cut with a tool that had an angle on one side and no angle on the other side, but was brought into the axle at a goofy angle to make up for it. Basically, cut with the wrong tool and a technique to compensate for it--as long as you're not seating the side gear all the way into the splines, it should be fine.
they'd have to be identical since they whole shaft has to turn in the side gear.
now, if both inner axle shafts look like that, I may have to change my answer. but my 60's front shafts don't look like that,
I have to agree with cut.
my front 60's splines look NOTHING like that though at all. Which is why Im goin with cut
bgreen said:
Side view on the left and end view on the right. The long verticle deal on the right is the endmill.
i agree 100% they were cut that way...i had some shafts cut by WMS and they came back like that...took me 1 day to twist them all to hell...
good luck. :flipoff2:
no i am saying use that axle till it pops then get a real axle made :flipoff2:
o and this needs to be said
Narrowed = PITA
now you know why i got rid of my narrowed 44 :flipoff2:
Heck no, lock that bastard.
IDK why people think locking up an axle is harder on it that lifting a tire, spinning said tire @ 2x ring gear speed and then regaining traction ......:confused:
Besides, the stub will probably let go first :flipoff2:
1 - 20 of 32 Posts
