Im gonna put new shocks on (ranchos) sometime soon. Which would you guys recommend? The 5000's or the RSX's? Also, I'm considering doing a u-bolt flip at the same time (rockstomper kit) and mounting the shocks angled inwards ( / \ ) using the mounts on the rockstomper plates and mounting the tops to the round crossmember. Would it be worth doing this even though I still have stock rear spring?? Will it increase travel at all? If so, what model numbers on the 5000's and the RSX's would I need to do this? Im running 1.5" AOR lift shackles in the rear if that makes a difference. Thanks guys!
