1 - 20 of 48 Posts
TBD, DD, Parts hauler, earth mover.
2002 Tacoma Prerunner 1 ton swap
2005 Ford super duty front
2003 GM 14 bolt w/ disc
Turbo LS w/ Holly terminator x max harness w/ pro dash.
4l80e w Atlas 2
Wheel Tire Vehicle Car Automotive tire
Automotive tire Wood Motor vehicle Wheel Gas
Wood Gas Nut Machine Automotive tire
Wheel Crankset Tire Automotive tire Bicycle tire
Automotive tire Gas Cookware and bakeware Auto part Machine
Wheel Tire Automotive tire Motor vehicle Tread
Motor vehicle Automotive tire Valve Asphalt Tread
Gas Drinkware Automotive tire Machine Automotive design
Automotive tire Motor vehicle Automotive design Gas Automotive wheel system
Automotive tire Gear Wheel Motor vehicle Engineering
Discussion Starter · #12 · (Edited)
Converting another trans. Over that! 4l80 2wd to 4wd. Using a free np261HD cause I’m broke and can’t afford an atlas. I’ll go back to that later.
Automotive tire Drinkware Wood Plastic bottle Automotive wheel system
Automotive tire Wood Gas Automotive wheel system Auto part
Automotive tire Motor vehicle Bumper Triangle Gas
Discussion Starter · #15 ·
This is where I’m at as of tonight. Started january to now.
Dom gonna be here this week. Hoping to wrap up front and get back to wiring the motor.
Automotive exterior Gas Auto part Machine Motor vehicle
Automotive tire Motor vehicle Wood Automotive wheel system Gas
Automotive tire Motor vehicle Gas Auto part Machine
Automotive tire Motor vehicle Bumper Automotive exterior Gas
Discussion Starter · #17 ·
Got to cycle some steering half assed. Got the link mounts kinda up but I hate them. Prob gonna do a DOM link mount.
Got the high steer figured out at least. Just have to clean it up.
Wheel Tire Vehicle Motor vehicle Car
Hood Gas Automotive exterior Motor vehicle Engineering
Milling Wood Drilling Jig grinder Machine tool
Automotive tire Motor vehicle Bumper Automotive exterior Automotive design
Tire Wheel Vehicle Automotive tire Hood
Discussion Starter · #19 ·
Tried to modify the stock Toyota steering shaft cause I ordered the wrong size joint. 3/4 means 3/4 unless it means 11/16.
Thought I could press out u joints and mix the shafts. No. Doesn’t work. Cut threads off to use and gonna convert to speed shop steering joints and shaft..
Wood Bicycle part Gas Window Tool
Wood Tool Hand tool Household hardware Blade
Shoe Light Black Walking shoe Automotive tire
Wood Gas Auto part Automotive tire Machine
Discussion Starter · #20 ·
Finally got some parts and part of my bender. Minus dies(lead time of course) Can start actually doing shit and get steering done finally.
Automotive tire Automotive lighting Audio equipment Asphalt Road surface
Thigh Flooring Human leg Plant Machine
Automotive tire Motor vehicle Bumper Wood Bicycle part
1 - 20 of 48 Posts
