1 - 17 of 17 Posts
proffitt'scruisers said:
Now available from Proffitt's Cruisers...the PROField. Simply the biggest, heaviest birfield on the market today. We guarantee that if you can fit this unit into your front end, it will never, ever, ever break.
(some fabrication may be necessary)
Bwaaaahahhahhaaaaa!! Awesome!!
JEremiah, thanks for the call tonight on the calendars!! I'll be checking my mailbox when I get home from my trip next week!!
with your new Pro fields do I still need to grind the inner knuckle of the housing?:confused:
and can I still run the stock hubs?????
:D :beer:
I think you might have some problems with all-pro in terms of trademark infringement for the name! :flipoff2: Here
Discussion Starter · #13 ·
WTF did that come from?
It's out of a road grader, and the inner race was actually broken. The bearings inside are as big as handballs.
Actually, I think I had the name first. This thing has been sitting around the shop being called the Profield for 3 years now.
heh, when I saw that thing this summer I knew it'd make it on the board sooner or later ;-)
the TornadoAlley crew sez "thanks for the calendars' call"
Steve
Rover Birf
Leafsprung said:
Ok thought some of you yota guys might be interested in this. Maxi drive in OZ makes custom swivel balls for Land Rovers from 4140 that accomidate 101 forward control one ton Rover Birfields which are huge. Might be a cool option for a cruiser. Heres a pic comparing them to standard rover CVs the 101 CV on the bottom uses 22 spline 1.5 inch diameter shafts.
-Regards
-Ike
shaka 55, I saw this on another thread. Picture of the Rover birf...
Re: Rover Birf
That top birf has the same balls and inner star as a minitruck, FJ60 birf, VERY VERY similar in size and design... interestingly enough.
1 - 17 of 17 Posts
