101 - 117 of 117 Posts
Trail Tech Fab
Discussion Starter #103
NP241 to Round NP205 kits sell for $550 shipped in the USA. A rear torque mount is recommended if you don't already have a method of supporting your NP205 from the back side. These sell for $60 when shipped with one of our other components. Let us know if you have any other questions. Lead time is currently 9 business days.
Regards,
Mike
Trail Tech Fab
860-341-1883
Trail Tech Fab
Discussion Starter #105
Does that inclued the adapter for the 4l80e 2wd to a 241???
The $550 covers the NP241 kit. We'll need a little more info on your 4l80 output shaft to nail things down. As a base line a 4l80E 4x4 output shaft to Round NP205 Infinitely Clockable Adapter kit welded by the customer sells for $345 shipped in the USA. Your 2x4 kit(assume you aren't planning on running the output shaft at full length) will be similar but we would need to work with you on the length of the adapter.
Regards,
Mike
Trail Tech Fab
860-341-1883
[email protected]
IDk if there is any change in pricing but let me make sure all this will work. DSD 241 to 31 spline PSD 205. fig 8 pattern (boring case for larger input bearing) shipped to 23860. Still 5 days on lead time?
Can you send me the measurement from the front of the 231 box to the rear of a ford 205 case, or to the center of the rear yoke?
Trail Tech Fab
Discussion Starter #110
I'll take some measurements this afternoon and get back to you.
Thanks,
Mike
Trail Tech Fab
Discussion Starter #113
What options would i have with a Ford t18 and np205 all 31 spline?
31 spline in a 241 is achievable by swapping in an input gear from a NP271. A needle bearing "adapter" needs to be machined to accept the smaller 241 needle bearing in the 271/273 gear. We do this regularly for our hardcore Diablo crawler boxes. It's likely not cost effective to perform the swap on the 241 unless you can do the machine work locally.
Regards,
Mike
If you are still making these could i get a price shipped to 87701 for a np241 to Ford 205 kit with the rear 205 support added in there.
+1 to the above question, DSD 241 to DSD 31 spline Ford 205, zip code 84325
So these guys are no longer building these I guess?
Does anyone know a current source for a DIY doubler setup to mate a Chevy passenger drop NP241C to a Chevy passenger drop long 32 spline round pattern NP205?
