1 - 2 of 2 Posts
Are guys using a tru bar to install uni bearing cups from spider trax or trailgear? Or can they just be pressed on and welded up?
They're designed to just slip over the tube and be welded. But if you plan to add alot of bracketry, or trussing to the axle, and don't have a press type fixture to add preload to the housing, odds are it will warp, making the housing ends not true.
We've done it with the preload jig, and still had ever so slight misalignments, and have offset machined the bearing pocket slightly, installed with a true bar, and added gusset's to assure strength.
1 - 2 of 2 Posts
