5 cylinder diesel engine out of a G wagon or W123 car is the easiest fit. If you strip the backing plate, flywheel and clutch of the mog engine and put it on the diesel, it will bolt straight up with no conversion plate.
You have to trim the cab floor and make good, make a new engine mount for the front, and a few other jobs plumbing and lining up pulleys, etc... I am about 50% through doing mine, and its not that bad a job at all. You have to lift the cab off to do it unfortunately.
If you want any info, or you want to come and have a look, give me a shout, I am only over in North Wales. I also know where there is another of these engines in a breakers for £200 if you want one.
