1 - 5 of 5 Posts
before i call AA, i just thought id ask around here...
anyone know if i can get different output yokes for my atlas?
im looking for one that will fit a 1350 joint.
thanks
~John
Call them I am pretty sure you can. My friend just bought a 4.3 Atlas 2 and he payed extra to have larger yokes installed. Now he might have problems fitting the required 2in. front driveline from his front d60 because of the th350 pan and case. I only wish I had that trouble.
You can get with your 32 spline front and rear if you get that one- (1310 non c/v and c/v ) (1350 c/v and non c/v ) and 1410 if you beg from them (and 1480 if your wanting to break your atlas) call me on that one- Good luck- Jess
The AA website (Atlas section) lists all the part numbers for the different spicer yokes you can use on the Atlas along with all the part numbers for the seals you need to use.
1 - 5 of 5 Posts
