1 - 4 of 4 Posts
I installed the v6 ARB 3rd member into the housing. For some reason the axle shafts will not go all the way in though. There is about a 1/8" left to go, something is hitting inside?? :confused:
This is for a rear axle.
Is there something I am missing?
· Wicked Raciest !
Put the nuts on the studs and try to pull it in by tightening in a cross pattern. Some times when you pull the axles the bearings pull out a bit in the cups, are cocked, and will not go all the way in. Only tighten the nuts about one-half turn then go to the next one. Works for me every time.
1 - 4 of 4 Posts
