marlin has a setup to dual case a V6 auto. i think you have to have the A340F though. he told me he had one ready to go for my T100. he did a guy's runner, but he had to swap the A340H for an A340F.Pazuzu said:I'm pretty sure the manual t-case is a separate assembly, like the 4-banger t-case, while the auto is for sure integrated into the tranny tail. I've spent many a beer sitting under the rig trying to find a way to dual case my V6 auto. I'm still trying![]()
Let me ammend my statement, I'm trying to dual case the V6 auto without dropping coin like that...the closest I've come is the pipedream idea of a divorced second case, and take the first case, remove all of the front wheel drive stuff, then slice it in half lengthwise, cap the opened area, and have a straight through reduction unit. The question is, are there important oil channels within the front drive area that will be destroyed?surlynkid said:
I love my V6/auto on the trail, no question. Just playing with optionsErikB said:I dunno how or if any of this figures into what you guys want to do, but I watched my brother in law ran Clawhammer last weekend w/ an auto and stock t-case and he didn't seem to have any problems.
The only problem he had was with the t-case shifter linkage, but I'm not sure why. We just disconnected it and shifted it by crawling underneath as necessary.
did you keep the factory cooler/lines and add the aux cooler/lines in series? if you guys got away with this setup at the hammers, im gonna keep the auto in my DD/campin 4runner and just put a solid axle up front...ErikB said:I dunno how or if any of this figures into what you guys want to do, but I watched my brother in law ran Clawhammer last weekend w/ an auto and stock t-case and he didn't seem to have any problems.
(that's one of the steep trails where you're suppossed to have a crawler...)
I did have him install an aux. tranny cooler though just in case. He put it where the old A/C condenser was in front of the radiator and wired the stock electric a/c fan to be switched manually to keep air moving over it on the trail.
It's Troy Muse. I contemplated that for a while when I had my V6 case, just to see how long it would hold up. I went for Inchworm's deal on 5.1's and 4cyl case instead.OOP'S said:Early model Nissan 4X4 (my 85 had one), had a divorced T-case hat you could use. I think one of the Pirates used one for a long time on his rig. He had a manuel but there is no reason you could not use one behind an auto. Just takes a bit of fabraction.![]()
Booger Weldz said:
did you keep the factory cooler/lines and add the aux cooler/lines in series? if you guys got away with this setup at the hammers, im gonna keep the auto in my DD/campin 4runner and just put a solid axle up front...![]()
Yup, same with me. Drop that pivot point on a rock and it's D-E-D dead.ErikB said:Then it got stuck in 4-hi and he couldn't get into 4-low at all and we looked underneath and saw that the little pivot that that G-shaped linkage uses had popped out.
