1 - 20 of 43 Posts
They are portal axles from a C 303 Volvo forward control truck. Often referred to as a laplander. Do some sniffing and you will see the advantages (for one they are made by a subsidiary of dana and would be compatible with D60 stuff). The rear dif location is weird but what I need for my application.
No I am not kidding.
I need a set for one of my peices of british crap.
Ron
Originally posted by evilfij:
<STRONG>They are portal axles from a C 303 Volvo forward control truck. Often referred to as a laplander. Do some sniffing and you will see the advantages (for one they are made by a subsidiary of dana and would be compatible with D60 stuff). The rear dif location is weird but what I need for my application.
Ron</STRONG>
A newbie that knows how to post! Welcome <IMG SRC="smilies/thefinger.gif" border="0">
Get a picture of a some and post them. Some people are using Mog portal axles but havent heard about the Volvo ones. They sound sweet.
Originally posted by ncwheeler:
<STRONG>http://www.xtremeaxle.com <IMG SRC="smilies/usa.gif" border="0"></STRONG>
Now that is cool:
Looks like the U-joint is before the reduction, and it looks like you could make a flange to bolt those knuckles to any axle. Any idea how rare and/or expensive these thigs are?
[ 10-25-2001: Message edited by: Grandpa_Jeep ]
There's a discussion going on about those things on the SRC site, under the 1 ton forum, something like "bet you can't name this axle".
Pete
Discussion Starter · #13 ·
//home.swipnet.se/~w-128002/matsprototyp.htm
Something like this.
Now you all non rover people don't want them as the rear axle has the dif offset the one above has two fronts I think
Makes everything else look like crap. ie you think you are hard core and you see something like that
There are a bunch in malaysia I am trying to buy as well as a bunch in Sweden and Norway. However, no one will sell me them without the rest of the truck and most of the trucks are <25 years old so no way to import. Going rate for a complete truck is 5k or so in Sweden. A junker they rust like crazy is about half that.
They would look great under my POS Range Rover.
Saw a 1963ish 109 on them with 35in Simex and it was styling.
Ron
Misc pieces of british crap
Originally posted by Grandpa_Jeep:
<STRONG>Looks like the U-joint is before the reduction, and it looks like you could make a flange to bolt those knuckles to any axle.</STRONG>
You should be bale to bolt the knuckles to any axle if you made an appropriate flange but from what I've read these axle have like 2.73s in the diff....all the redcution is at the hubs. I think it would be sweet for soemone to take a D60 and put these on there. Lots of work but it would kick ass <IMG SRC="smilies/eek.gif" border="0">
Discussion Starter · #16 ·
Interesting reading on the SRC board. Finally figured out what SRC stood for.
We kinda went over this on the D90 list about 6-8months ago. What is the market price for a set of C303 axles? I have enough leads in sweden to maybe have my importer make a dedicated trip.
For more pics did up the land rover mags covering the malaysian challenge a couple years ago. There is a nice pic of the 109 upside down showing the drive train which was all early 60s stock rover, save the axles.
The axles litterally bolted right up. The flange on the pinion looks to be a rover driveshaft bolt pattern as well.
This is why I want them. The mog axles are probably a much better idea for non rover types or some similar application, but these will make my british crap happy.
As far as modding them I am pretty sure they were made by salisbury which is owned by dana. Earlier laplanders had D44 clones, not D60 clones and I was told the interals in the 303 dif of the were compatible with D60 parts but have not confirmed.
Ron
Originally posted by BabyWrangle:
<STRONG>You should be bale to bolt the knuckles to any axle if you made an appropriate flange but from what I've read these axle have like 2.73s in the diff....all the redcution is at the hubs. I think it would be sweet for soemone to take a D60 and put these on there. Lots of work but it would kick ass <IMG SRC="smilies/eek.gif" border="0"></STRONG>
I wouldn't think you would need a D60. Most of the reduction is in the knuckles, get yourself a D30, truss it and go. Not to mention, you would have even better clearance.
<STRONG>Interesting reading on the SRC board. Finally figured out what SRC stood for.</STRONG>
Where is the SRC board, and what does SRC stand for?
<STRONG>...from what I've read these axle have like 2.73s in the diff....all the redcution is at the hubs. I think it would be sweet for soemone to take a D60 and put these on there. <IMG SRC="smilies/eek.gif" border="0"></STRONG>
Dana 60s were available with 3.08s. They came in the early Dodge Cummins trucks with the 727 trans.
Pete
<STRONG>Now that is cool:
[ 10-25-2001: Message edited by: Grandpa_Jeep ]</STRONG>
That company is selling them for 7900 front and rear. <IMG SRC="smilies/eek.gif" border="0"> Supposed to be equal to a 6.17 gear. Be nice to be able to just get from the flange out.
1 - 20 of 43 Posts
