Ok, so I shopped around for a wire harness for my 5.7L Vortec...not many around. Matter of fact, I only found one guy, Scott at the Detail Zone. The guy specializes in hot rods and other nice cars. The harness he builds would be great for that purpose, but for off-roading...not so good.
First of all you, you have to route every plug, every wire. It does not arrive at your door step in split loom...ready to be put on. So, each plug has the plug and about 12-16 feet of wire (long enough to allow a guy to wire the computer into the trunk of his car)... Plugging the connections in and routing the wire was kind of fun. I got to put all the split loom on, and basicly manufacture what my harness looks like, and make it as clean of an install as I wanted.
Now that all the wires are routed to the location the real work starts! You have to cut every wire to length, then crimp on a fitting and screw it to a board that will then route your wire to the computer. Oh, I think there are over 100 wires!!!!
Well the board you wire it to is not water proof...at all. It is not dust proof, and with all the bouncing we do...would be prone to have wires come loose!
After my motor did not start, and after buying a ton of extra's to make this wire harness work I found out that Howell makes the wire harness that we are after...just plug in the connections, and plug in the computer! So, Scott took my cut-up harness back! And I ordered one from Howell 810-765-5100 (oh, the Howell one is $150 cheaper too!).
Here are a couple pics to give you an idea....remember these pictures do not do it justice...it is actually WAY worse than this.
Once again I WOULD buy this harness for my hot rod. I think it is a cool idea, and I am happy somebody offers it.
