1 - 2 of 2 Posts
First off, i have searched every link possible that i could on this board and many others. I'm still confused.
I have a 1985 Jeep CJ7 with a Turbo 350 tranny adapted to a Dana 300 Transfer case. I want to put in a 1999 Vortec 305.
I've got most problems solved, the big one now is this VSS, or Vehicle Speed Sensor. I have no idea how or where to get a signal for it.
Do i need it? Does anyone make some sort of adapter? If so part numbers would rock. Can i get the computer reprogrammed to not need i.
Please let me know what you think and thank you ahead of time.
The vss runs the speedo and electronic transmission as far as shift points. You may be able to get by with out it on a th350 if it doesnt affect the engine. If it were me I would use the old speedo from the jeep and run with out it and check to make sure you are not throwing any codes and if everything is good I would tape and tuck the wires out of the way keeping them in case you decide to do more mods in the future.
1 - 2 of 2 Posts
