1 - 20 of 25 Posts
I was wondering what the differenc in the width between an '84 waggy 44 front and the stock tj 30 <IMG SRC="smilies/question.gif" border="0"> I am going to be building this 44 and also wanted to know if anyone has any tips or good ideas for me in this swap. Thanks. <IMG SRC="smilies/smile.gif" border="0">
If I remember correctly the Wagoneer is 60.5" and the TJ is 61"? Only half an inch and is un noticable. Some Wagoneers had narrower axles and some had wider (63").
When I took a tape to it, it was roughly within an inch of oneanother. The 44 has some sort of vacume hose on it and has a different diff cover on it. I think it was for the auto hubs on it. Is that going to be a problem to change over to normal hubs?
DO NOT get an 83-84 waggy front 44.
they are vacuum activated and very nasty. any other year of waggy (to my knowledge) will give you a hub-able 44. try for a command trac (PT4WD) front axle. those should already have warn hubs.
if you've already gotten it, try an sell it to some dumbass on JU <IMG SRC="smilies/wink.gif" border="0">
If you already have it, can't you just measure it?
The Waggy fronts are 62" WMS to WMS, whic is a little wider than your TJ.
Yours has a center vacuum disco, which as you noted is located in the centersection (NOT the long tube like a YJ). For those looking, the diaphragm is visible coming out of the diff cover. This disco was on some 83s and 84s.
You can put hublocks on, but you still have the center disco.
I would follow the previous advice and sell it (I know...I know ...its a PITA), and find one from any other Wag or GW except those 83 and 84s.
Charly
Originally posted by high5:
<STRONG>can you swap the long side shaft (the one with the disco) with a one piece unit from a earlier or later year? just curious.</STRONG>
No. These had the disconnect integrated into the same housing as the pumpkin, not outboard in the middle of the long shaft like a YJ or XJ.
You need a Waggy from '87 to 91 to be certain that you get on with a drivers-side differential but without the disco.
HTH,
Jake Harsha
What's that you say Charly <IMG SRC="smilies/thefinger.gif" border="0">
<IMG SRC="smilies/grinpimp.gif" border="0"> <IMG SRC="smilies/grinpimp.gif" border="0"> <IMG SRC="smilies/grinpimp.gif" border="0">
How about this, block the disconnect mechanism so that it's locked all the time and replace the slugs with hubs. Not the best solution, but might be worth it since you already have it.
Discussion Starter · #20 ·
Does anyone else think that will work or is it not worth it. Also I can't figure out how to put someone elses reply on my reply can someone tell me how to do that because I am Really STUPID I GUESS <IMG SRC="smilies/confused.gif" border="0">
1 - 20 of 25 Posts
