Ok I know I am going to take some sh*t for this but anyway here goes, and yes I do use the search alot on this board. I have my YJ coverted to SOA with stock 7 leaf waggy springs and am running 35" BFGs on waggy dana 44s. I have the wheel base extended to 102" and that looks like it will work well but it is tall!! I will be removing the 2" body lift that I have been using for years when I was SUA, what I am wondering is how long will the waggy springs last if I only run 4 of the seven leaves, I want to keep this as low as possible. The front fenders and have been removed and will not be used and the rear corners have been cut so I should have plenty of room for the tire, I just want to make it more stable, but if I am going to wreck the springs the first run out by only running 4 of them then I need to look at doing something else. Let me know what you guys think.
Kris
Kris
