1 - 5 of 5 Posts
New to axle mechanics...I need to replace the seals on a 82 Wagoneer front axle. Is this a seal in the pumpkin or near the tube end? Any help is appreciated.
im guessing you are leaking fluid out the ends.. you will want to replace the inner axle seals.. they are located inboard.. near the differential bearings..
What JeepGod said! <IMG SRC="smilies/smile.gif" border="0"> I just replaced all my bearing and seals when I swapped the gears and spool in my 82' waggy front.
damn, I priced those seals locally, and they are $17 a piece!
is that normal?
1 - 5 of 5 Posts
