1 - 20 of 21 Posts
Hey I've got a CO2 tank and I'd like to make a source for air. Has or does anyone know what's needed to make it work? I know Power Tank makes a kit fot it but I think it uses scuba tanks and I don't have $200. Are they any different from tanks used for welding for example? Any help would be great.
There is 300 + pages of posts containing "power tank" on this BBS
to answer your question;
Yes it will work.
An air valve.
You could buy that kit..... Or build the same kit yourself.
No I dont think it uses scuba tanks. They are just plain air tanks. Nothing special.
They are just like water fire extinguser tanks. In fact that would work. Your only talking about like up to 175psi here. Not 3000 like a scuba tank.
Your welcome, that way you dont have to wade threw all the search pages.... It gets to be a waste of time.
Bert, 175psi ? my CO2 hold something like 900psi or so.
You can use a regulator for a nitrogen tank. Go to your local welding supply shop and they can help you. I used a CO2 tank that they use for fountain drinks. Works great.
Yes it will work.
An air valve.
wow you know how to be a smat ass but you are that smart:flipoff2:
no it more like 2200psi and then it is regulated down to a usable pressure like 90-100psi
cliff
wow you know how to be a smat ass but you are that smart:flipoff2: ...
...no it more like 2200psi and then it is regulated down to a usable pressure like 90-100psi
Let's see if I got this right -- you corrected the previously-correctly corrected correction with an incorrect correction, accompanied by an attempted-but-missed smack (is that an air-smack?)?
Well, in a nutshell -- THAT was a swing and a miss. :shaking: :rolleyes: :shaking:
A few points:
* Power Tank uses aluminum cylinders that are service-rated for 1800 psi.
* Actual cylinder pressure of the C02 gas over the liquid in containment is 700-800 psi (depends on temperature)
* The Power Tank regulator is adjustable from 0-150psi.
* The spec you posted is close to what you'd want to run an ARB.
Thanks for playing, and we have some fine consolation prices backstage... :p
Randii
Randii you beat me to it
CO2 is a liquid and to stay a liquid it needs to maintain a pressure of about 800 psi thats why when you let it out it turns into a gas.
If you were talking about scuba tanks you were much closer my aluminum tanks are filled to 2500 psi and yes the reg brings it down to about 100psi
If anybody is interested I have a few old steel scuba tanks if any body wants them for some pepsi I think I have 5 out in the shed.
Don't ask me if you can install a valve to run CO2 because I don't know.
cliff
Cliff , nitrogen runs at up to 3000psi and like posted above CO2 is 800-900 psi. We use nitrogen at work and if it wasn't at such a high pressure I'd be using it (free :D). But because it's at that high of a pressure it's not as safe as CO2.
Discussion Starter · #12 ·
air tank
Thanks Guys, I don't do searchs because the achive is SO big that it'd take absolutly for-ever to look thru everything. It's much easier to take some heat from guys who feel like they must give everyone shit. I don't have time to wait for my slow ass computer to loud 300+ pages while I'm poaching the internet at work. Thanks again
Correct me if I am wrong, but most of the high end paint-ball guys run nitrogen rather then CO2. Safe enough to run around with and bang against rocks and such, should be safe strapped to your cage.
I don't know anything about paintball guns but the nitrogen cyl's we have a work are too big to strap to the cage. I guess I could get a smaller tank but it only cost $10 to get my 20# tank filled and I have only had it filled 3 times in the last yr.
As an FYI, the Advance Air (Powertank) regulators are spec'd to run at 8CFM all day without freezing up. They can also (possibly) be had for cheaper than new if you call and ask if they have any refurbished ones. I got one for ~$45.
Bryan
in equally sized containers would the high psi nitrogen in a gaseous form provide more volume than the co2 in a liquid form?
My 20# CO2 tank is 7.5" x 22" and stores 168 Cubic Feet of CO2. A similar size N2 tank would would be considered a 55 Cubic Foot tank. Remember we are comparing Apples to Oranges here. Change of state for the CO2 and Boyles Law for the N2.
1 - 20 of 21 Posts
