1 - 13 of 13 Posts
thank you for that chart. i have about 20 old ford trucks and bronco from 66-79 that i part out in WA. and that chart will help. the chart does say that the 77 has a longer stub shaft 10-21/32. 77 3/4 ton disc brake used a external hub.
randy
waterboy
sure no problem. gues I should paid more attention. so the f150 shafts are the same, but the 76-early 77 stubs are longer and bigger.
you wouldn't happen to have what I'm looking for would ya?? this axle orginally came outta a late 77 F250 and has the shorter shaft.
is the only difference the length?? or is the diameter different also??
1 - 13 of 13 Posts
