1 - 7 of 7 Posts
WARN Winch for sale in Virginia:
WARN 8274 w/remote $550 OBO
Works fine....FAST line speed.... Cable, Remote, & Fairlead included. Sick of seeing it sitting in the garage since it is a bit too heavy for my Samurai!
Serious inquiries E-mail me at [email protected]
Sean DeVinney
What's the tow weight max on that 8274 . . . looking for something with 9000lbs for a friend...
Z
Here are the specs from the website:
M8274-50 SELF-RECOVERY WINCH
Loved by off-roaders who compete for prizes, the WARN M8274-50 is one of our fastest winches. No load retrieval speed is 73.4 feet per minute. At 150 feet of 5/16" cable, it also has a very long line capacity. Its unique spur-gear drive train and upright design are totally rugged and its braking system delivers smooth operation with superior heat dissipation. Roller fairlead, remote control on 12-ft. lead, free spool clutch and battery cables are included.
M8274-50 SPECS/PART NUMBERS:
Part Numbers: PN 38631 (12V DC), PN 386312 (12V DC, CE) PN 375832 (24V DC, CE)
Rated line pull: 8000 lbs. (3630 kgs.) single-line
Motor: 12V 4.6 hp/3.43kw, 24V 2.5 hp/3.43kw, Series WoundTM
Remote Control: Remote switch, 12' (3.7m) lead
Geartrain: Spur Gear
Gear ratio: 134:1
Lubrication: 6 oz. SAE 30 (non-detergent)
Clutch (freespooling): Sliding Motor Pinion Gear
Brake: Automatic, disc type
Drum diameter/Length: 3.5"/8.5" (9cm/22cm)
Weight: 110 lbs. (50 kgs.)
Wire rope: 150', 5/16" diameter (46m, 8mm diameter)
Replacement wire rope: PN 26749, PN 38311 (CE)
Fairlead: Roller
Recommended Battery: 650 CCA for winching
Battery leads: 2 gauge, 72" (1.83m)
Finish: Argent Powder Coat with Clear Coat
Nuts:/bolts: PN 7616, L/W: PN 2146
Bolts: PN 7165
Winch Dimensions: 16.5" L. x 8.5" D. x 15" H. (420mm L. x 220mm D. x 381 mm H.)
Mounting Bolt Pattern: 10.0" x 4.5" (254mm x 114.3mm)
It is a 8274. The 8274-50 is the only one I could find specs on....the specs are very similar, but I am not that knowledgable about winches so please pardon any mistakes.
E-mail me if you have any Q's.
Sean
1 - 7 of 7 Posts
