1 - 8 of 8 Posts
Yes, its cheaper, but not much fun.
You've gotta grind the welds and take the inner steering knuckle yoke off the tube.
Then get yourself a CJ housing and steal the yokes off that one, weld them onto the XJ tubes, making sure to get the ball joint centerline in the same place.
Now use the CJ stub axles and outers, brakes, hubs etc.
Of course this only works if you have the same u-joint size.
sounds like too much work...
as much as i like to fabricate.. I think i'd rather work a few extra days and send warn a check for 850....
eheh...
I have a dana 44 for the front but i think someone put the axle tube in crooked... how could i tell???
eheh...
Sounds like you have more of those 850$ checks than I do...
Waggy outers with 44 flatop knuckles, home brew steering arms and linkage, K-5 inner knuckles - then trussed
All told with the parts axle I was under 400$ (including everything you see below on the axle).... To each his own - but I'm broke with no $850's in the forseeable future...
Matt
1 - 8 of 8 Posts
