1 - 4 of 4 Posts
Yamaha 350 Warrior ATV, or the warrior bike? The ATV I can go look at my book if needed.
i believe your engine oil and tranny oil are the same in that quad. you should use a motorcycle grade oil. 10w40 will do and it should hold 2.6 qts if you change the oil filter. if not then 2.5 qts
by the way i highly recommend suzuki's 10w40, it is a great oil and not that expensive. i ran it in all of my machines weather suzuki or not.
1 - 4 of 4 Posts
