With a leaf spring, full size rig, Wheelbase in. 106.0, Overall Length in. 188.8,
Overall Width in. 79.5, Weight lbs 5200.
What is the best way to run the suspension for washboard roads?
I would also like it to perform in the twisty stuff to but not major twisty. The rig is also a so called daily driver 1-2times/ week but has to run the hwy for getting me to destination.
I'm thinking softer and more thinner leafs in stead of thicker. reverse shackle in rear, Shocks at a more upright angle with a slight aft to rear, long as posible thru floor, mounted out as far as I can. Tires with about 25psi. Sway bar front with a disconnect for more articulation in the twisty.
I don't want to go coil spring. Leafs will be made by custom spring shop. lift will be 3.5inch, 33" tires. Any suspension guru's.
Thanks for any info.
