I wanted to kick this off because I will be building my motor for the Hotrod. For tech if you use the roller rocker from Murphy's machine shop you will need to fab up spacers for your valve covers. The rockers are too tight to fit under the stock covers:mad3: I will update when I have the motor built. I also have the truck torn down for paint and powder coat. The goal is to blast around in it this spring
Here's the link for the build.
http://www.ihonlynorth.com/forums/readers-rides/7484-34-hot-rod-pickup.html
And I also wanted to see if Chi has started on his Scout yet, I hear he has a killer shop now:flipoff2:
