1 - 3 of 3 Posts
Ok I searched and found all kinds of stuff about welding cast but I'm still not sure what I should do.
I broke a 465/205 adapter a while back and would like to weld it up for a spare. So my ?s are :
Is this adapter cast IRON or cast STEEL?
How should my technique vary from 1 to the other?
Can I weld it with my miller 135XP mig? (my only welder)
What wire, what gas?
What should I preheat to and long should I let it cool?
I'm willing to buy a roll of wire to attempt this but I don't wanna pay somebody to stick weld it with nickel rod since its just gonna be a spare.
And if I'm a retard and this can't be done with a mig, tell me and I'll try to gas weld it.
Nose to grindstone
that cast is soo saturated with oil you may not be able to weld it without cleaning with heat soundwaves and tricloromethane but I have gotten lucky with a tig and a old 20 case. I would give it a shot, drill a small hole at the end of the crack to ensure it will stop and then fill the crack just like your prom night :flipoff2:
"Try to gas weld it" ???? Have you done this before? The filler you use for gas welding is nasty stuff...but very effective. Last time I used that my nose bled for 2 days. Really nasty fumes and I never used a resperator. A guy I know was prolly one of the best cast iron welders in Canada...companies used to fly him all over North America to fix huge industrial castings. He now sells cars for a living...the fumes from welding cast ate out the lining in his throat and he has serious lung problems. Do a spark test on that adapter. If it has a dirty, short , dull red spark it is most likely cast iron. A brighter, yellow, longer spark would be a cast steel most likely. This you could weld with a mig with proper prep. We weld cast steel with 7018 or LA T-91 on a regular basis.
1 - 3 of 3 Posts
