1 - 20 of 28 Posts
Well, the tank is empty, but still smells of gas. It was just made, and there are a couple places where it is seeping or sweating out. I have ground down the welds, and want to weld the seams again, but I am afraid the gas will ignight...any ideas?
Is there a chemical I can put in there to Neutralize the gas?
Oh, it is a steel tank.
Thanks.
I have welded my tank I washed it of a few time with TSP and very hot water, rinced it out a few time, let it air dry for a few days then welded it, no problems. Whay you can do is pip your car exhaust into it so ther is no air for ingnition
Be careful you don't have any air pockets. I had one 'pop' a little when the small air pocket was ignited. Mainly cause I had the part to weld at the top and that is where the air pocket was. Have also heard to purge it with carbonmonoxide (exhaust gas) but have never tried that. Just don't use hot exhaust gases if you try it.
Thanks.
Hi there, it's me again. Yes, you can take the hose off of the Argon/Co2 mix bottle, crank the regulator open and purge the tank with it. Keep it flowing while you weld it up. No oxygen, no combustion.
We have also plumbed the exhaust from a Honda into a gas tank before to weld it up. Heat from the exhaust gets more of the fumes out and the Hondas burn clean enough that they don't add any more. Also a non-oxygen atmosphere.
Discussion Starter · #11 ·
I have a friend with a CO2 bottle I was thinking about borrowing. How does that sound?
What is TSP? And were can I get it?
IH/Rover Moderator
TSP=Tri sodium phosphate. Don't worry about it you don't need it.
Discussion Starter · #14 ·
OK, so if I get the CO2 bottle, how do I use it??? This is what I am guessing...please let me know if I am right.
plug all the openings in the tank, excluding one. Place a hose, which will supply the CO2 into the tank into the open hole. Plug this hole with a rag, not quite tight enough so the CO2 can circulate out, but no O2 can get in. Start welding. Now I have to go all the way around the tank...probibly 60"...do you think I will have a problem?
Thanks,
Ryan
PS. All the gas is out of the tank. The rest of it dried up today in the sun.
I have done this quite a few times repairig aircraft fuel tanks when I am in a hurry or when they run auto gas works good as I'm still around and It's cheaper then purging with argon .
rich
Discussion Starter · #18 ·
So, since there is not an actual drip, it only seems to sweat...should I use epoxie or something similar? I saw something like this at Pep Boys....would this be a long term fix...sure it is safer, and that is what I am going for...
What do you guys think???
Discussion Starter · #20 ·
So what are you trying to say??? It's hard for me to read between the lines! Soon as I get my rig done, I may change it to that...it won't be as sexy, matter of fact, nobody will notice my aviater anymore
1 - 20 of 28 Posts
